Replacing rake baord, what to do about rofing nails?
georgep | Posted in Construction Techniques on September 3, 2016 11:29am
Hi,
Not sure of the proper terminology of the trim parts but I am replacing the rake board and the smaller piece of trim on top of it.  The edge of the asphault shingles is nailed into the rake board.   I planned to cut the ends of the nails off but am wondering if there is a better way to handle them.  Also, does the roof need to be renailed?  I don’t see how to do that unless I nail the shingles from the top and seal the nail heads.
Thanks,
George
    coonass | Sep 03, 2016 05:08pm | #1
    George,
    Pry the shingle up by sliding a wonder bar along the glue line until you can remove the nail. No need for shingle to be nailed into the facia.
    KK
  2. finefinish | Sep 05, 2016 07:48pm | #2
    Yup what Coon said although I would add that the shingles don't need to be nailed into the rake trim, but they do need a nail very close to it.  In other words if removing the nail into the rake means the next nail in that shingle is more than 4" away from the rake I would certainly add one close to the sheathing edge.  To do this you will need to lift the shingle above and sneak a nail in under.  This can be difficult to do without damaging the shingles especially if they are old and brittle.  A nice sunny warm day will make this work easier because the shingles will be more flexible.  Trying to cut the nails will most likely cause more damage than using a bar to pull them.
