Replacing Siding including 2″ Foam and Rainscreen
user-1110959312 | Posted in Construction Techniques on September 30, 2013 09:22am
We are currently starting the process of replacing the vinyl siding on my house, which our family owned company installed 10 years ago, before I was involved in the business. We are replacing the siding with LP Smartside lap siding.
The plan is to cover the current Tyvek with Tyvek Drainwrap, 2″ of EPS foam, 3/4″ furring strips as a rain screen, and then the siding. We will be using Cor A Vent SV-5 siding ventilation.
Our home was poorly insulated with fiberglass batt insulation within the 2×6 stud cavities when it was first constructed, hence the additional 2″ foam.
When we removed the existing siding, I discovered that the Andersen windows were installed without any flashing details, with the Tyvek wrapped into the window opening, and the window installed on the outside. I am planning to just install the new drainwrap over the existing Tyvek, with a header flashing detail and Tyvek straightflash on the sides.
I have used a research paper by Peter Baker for much of the planning for this project:
http://www.buildingscience.com/documents/reports/rr-1204-external-insulation-masonry-walls-wood-framed-walls/view?topic=resources/retrofits
Any thoughts on this?
Chris Rautmann
  1. user-1110959312 | Oct 01, 2013 11:02am | #1
    This is near Milwaukee, Wisconsin, climate zone 6.
    The windows have nailing flanges.
    The windows will remain as installed, with external extension jambs applied of the LP Smartside trim material.
