Replacing weather-worn brick on facade
lineup | Posted in Construction Techniques on May 26, 2003 06:28am
I’ve been asked to replace approximately 20 brick at the base of a home which has become discolored over the years from water action.  I can’t remove those brick because it would compromise the structural integrity of the facade.  I had thought about removing approximately 2″ of the discolored brick, cut brick taken from the porch and using thinset replace those brick removed.  I had also considered painting the brick with a matching color of the existing brick unaffected by water.  Any thoughts?
  1. Piffin | May 26, 2003 07:49pm | #1
    I'm thinking leave it there and find a chemical cleaner.
Versatile Vise
