Due to a serious roof leak the drywall ceiling, walls and blown fiberglass attic insulation have been saturated. How do I know what can be salvaged and what needs to be replaced? Should I expect future problems to arise such as nail pops if I leave the drywall to dry out. What should I do about the ceiling light fixtures that received moisture. All comments will be greatly appreciated.
The FHB Podcast team weighs in on Building Science career questions.
So it's "Ace", is it? Tell 'ya what, sport. Replace all the drywall that got wet. You'll have future problems with painting. Besides, you may have a lingering, oh, I don't know, is it mouldy? smell.
As far as nail pops, I'd think you would have the opposite problem; a mushy wall that bows out between the studs. (Oh, you can fix this? How, more nails and mud?)
As for wet FG batts, you can reuse, but a lower R-value. Cellulose? Can't say, but may, again, be source of that fresh smell, if you know what I mean, and I think you do.
Cheerio!
Ace, talk to your home ownner's insurance agent, your may end up with a nice budget to work with.
Ditto on what Rich said, Ace. Depending on how wet it got, you may have quite a chore. I would wait a month or so, and check it out. It the stuff is spongy, or you see the tape peeling, I would sure want to give it a close inspection.
We installed a roof this fall, and the tarp blew off and the homeowners ceiling got quite wet. I talked him into waiting 60 days, and you would be surpised how much better it looked. We ended up replacing only two sections, and taping mudding another two, and re-painting the whole show, a lot less than I had imagined.
Hope this helps.
Thanks for the replies! Insurance has agreed to replace all cracked drywall and all drywall with loose tape joints. Sealant and paint should cover all faint stains. A dehumidifier helped provide dry conditions and may have saved some future damage.
