Replacing worn out mortar
Sanetracy | Posted in Construction Techniques on September 4, 2023 10:35pm
Hello,
        I own a fieldstone home, circa 1850.  The original mortar, as seen crumbling in the basement, appears to be a combination of sand, clay and lime.  A great deal of it has fallen out over time into the basement leaving deep gaps between some of the stones, some gaps two to three inches deep.  I have three questions.
1) as of 2023, is there a mortar that is better at keeping moisture to a minimum in a partially below grade basement other than lime mortar?
2) if i fill in the voids, and decide to plaster the surface smooth, are there any additional steps I can take to minimize moisture transfer through the basement walls?
3) part of the basement has wainscoting.  I have no idea if there is a vapor barrier behind the wood.  If I wanted to place wainscoting around the rest of the basement, what should I place between the wood and the stone wall?
thanks for any advice
  1. stamant | Sep 05, 2023 03:38pm | #1
    look at the National Park recommendations.
    would consider 1:1:4 -- portland cement/lime/sand mix for repointing.
    https://www.nps.gov/orgs/1739/preservation-briefs.htm
    lime parging or lime-wash is a good traditional coating for below grade masonry wall interiors. the lime helps control moisture.
    would be very careful about wainscott since you may make conditions favorable to mold. [dark, cool, moist, and food source.]
    1. Sanetracy | Sep 05, 2023 05:53pm | #2
      Thank you very much!
      There seems to be a popular (online) anti-Portland sentiment when repointing old homes. What is the risk if it’s an interior versus exterior wall?
      1. stamant | Sep 05, 2023 09:22pm | #3
        straight portland cement is too hard and doesn't have the water resistance and elasticity of a portland/lime mix. mortar is sacrificial and protects the stone by failing first. if the mortar is harder than the stone, then you can get face-spalling during freeze/thaw expansion. ice is about four percent larger by volume than water [from what i remember]
