reroofing a rolled roof.
strandomania | Posted in Construction Techniques on August 12, 2008 08:51am
A neighbors rolled roof is leaking. It appears to be 2/12 pitch and is at least 15 years old. It appears to have ice and water shield under it. Can I put another layer of rolled roofing over this or do I have to tear off the old? Any other suggestions?
Strando
    jagwah | Aug 12, 2008 09:18pm | #1
    Depends on how rough the old roofing is. I would remove it if it's pretty broken up even if not it will just make for a better job. Reroofs never last as long as new roofs.
  2. Piffin | Aug 12, 2008 10:22pm | #2
    Life expectancy for rolled roofs is no more than ten years so it is probably in bad shape with a lot of splits and curled edges that will make going over it more difficult. Will probably be easier to tear it off and re-roof with new than to overcoat it.
    There are new peel'n'stick mod bit roofing products such as Polyglas that are reinforced, easy to apply without nailing, and are internally re-inforced that make a much better job than the old roll roofing.
    BTW, I notice Jagwah and I use the term "re-roof' differently. To me, any house that gets another roof is being re-roofed, whether the old is torn off or not. Looks like his context is that a re-roof for him is going over the old one.
      jagwah | Aug 12, 2008 10:34pm | #3
      Ya, around here it's used both ways. Not to many words meaning roof over existing, maybe overlay. I often abuse words.
      I got lambasted by e-mail when I went to work for the theater dept. at the local college because I used the word stringer referring to a part of a staircase instead of the proper theater term carraige. They were mad that the Division Chair had hired a theater illiterate. I laughed my buttocks off but the DC gave me a book on terminoligy and asked me to educate myself. I'm now theater literate.
      1. Piffin | Aug 12, 2008 10:56pm | #4
        I wasn't criticizing you. just clarifying so the OP would not be confused un-necessarily.Now onwards with the necessary confusion...;)
          jagwah | Aug 12, 2008 11:04pm | #5
          Didn't mean to sound as I took it that way. Just I find such things interesting.
          Like how they got mad in the theater for me calling pipe scaffolding Tube-Loc instead of Cheeseburro? Brand name like mine I suppose.
    2. strandomania | Aug 12, 2008 11:57pm | #6
      Thanks for the info. The roof is under a big maple and never gets any sun so it still looks ok. But I hear you on the strip off advice.
      What do you mean by "mod bit"?
      Thanks again.
      1. Piffin | Aug 13, 2008 12:09am | #7
        modified bitumen
        1. seeyou | Aug 13, 2008 01:50am | #8
          I thought it meant what happens if you break the new double secret Tavern rules.http://grantlogan.net
          .......now there's a Batman.....
        2. strandomania | Aug 13, 2008 06:02am | #9
          Thanks,
          Sounds like something out of a Sci Fi novel..mod bit. Ever read "Dune"?
          1. Piffin | Aug 13, 2008 06:25am | #10
            Paul Maud Ib?
          2. strandomania | Aug 13, 2008 03:17pm | #12
            exactly!!
  3. cargin | Aug 13, 2008 07:06am | #11
    Strand
    I second the tearoff and use peel and stick roofing.
    Menards carries peel and stick $87 /sq
    DIY friendly
    Make sure the roof is very clean.
    Rich
  4. BryanSayer | Aug 13, 2008 06:58pm | #13
    Strip off and use a single ply rubber roof, like TroCal or EPDM. Use the thicker stuff, 0.060 for EPDM.
