Reset thermostat to read in deg-F (Wirsbo radiant heat-only A3030101)
My stupid FIL fiddled with one of the t-stats (Wirsbo Radiant Heat-Only A3030101, see pic attached) and now its output is reading in centigrade. Two buttons on the front are used for all programming, and I need to know how to sequence through to make the change from deg-C to deg-F. Uponor’s website locks up whenever I try to download the owner manual for this thermostat. Anybody here know for sure what to do?
Well, I can't find the manual
Well, I can't find the manual for that one, but for a related model, "Press the mode button until the display shows temperature units. Press the +/- buttons to select the desired temperature unit."
Your FIL figured out how to change it to Celsius. I'm thinking he's not the stupid one.
Just saying...
He's 87, can't speak as a
He's 87, can't speak as a result of a stroke he had in 1991, and is a slow creaking unit.
A fiddler, he has screwed up every digital thing we have in our house and cars, by playing with buttons when we are not looking. Our remotes for the TVs and other toys are a wreck, we've got open owner's manuals all over due to the fixes we have had to make, and now my wife's car beeps and gives warning messages when she exceeds 4 mph.
And my DW and I are yelling at each other, blaming each other for all the situations, trying to dig out owners manuals, etc.
Life's a mess with this old guy living here.
And he just plays dumb, not admitting that he has touched a thing.
Stupid was the wrong word. What would you use?
There's no mode button on this model. Just two buttons marked + and -. Pressing and holding both at once gets me somewhere, but I cannot figure out any other steps, because all combos of button presses after the two-and-hold press (which makes the output characters all flash intermittently) get me nowhere.
I looked for quite a while for a manual or instructions, no go.
If you hold both buttons down what does it do? I read on a similar model that you press the + button after the menu comes up until it says temperature then use the - button to change f to c.
You sure the cover doesn't
You sure the cover doesn't pop open to reveal some other buttons?
Email this guy, he can probably help out.
http://cgi.ebay.com/Wirsbo-Uponor-A3030101-W-T-1-Heat-Only-2-Wire_W0QQitemZ180462063979QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2a0460916b
