A gas line went off house meter underground 18″ to garage entering building alongside foundation and then through wall. Later a slab was poured over the gas line for a lean-to. Illegal?
Prescriptive codes don't address the connection at less common angles, so base the connection off more typical ones using bolts, structural screws, blocking, and steel tension ties.
Yes, illegal.
