Residing with ‘rainscreen’ siding
| Posted in Construction Techniques on September 18, 2004 04:04am
I am planning to reside my 1943 Cape Cod with horizontal wood siding replacing the very poor aluminum which covers the original and even worse ‘fake wood’ shingle.  I intend to follow the advice I’ve seen several places and install the siding as a ‘rain-screen’, nailing it over furring strips to set it off from the sheathing by a little bit.  (E.g., Taunton’s “For pros” siding book.)  Also, I hoped to take the advice in FHB #160 (Jan. ’04) of covering the sheathing with foam insulation, either XPS or polyisocyanurate, then putting the furring strips over that, then siding.  This raised a questions for me, and I’d appreciate any advice.
The windows (recently replaced, Pella double-hung) only extend 1-1/4″ from the sheathing.  Two inches of foam would go past the windows before they even had furring strips and trim installed; even one inch of foam plus 3/8″ furring strip would pass the outside edge of the window.  How can I use this insulation/ siding method and still tie attractive and weather-proof trim into the windows?  Of course, the same issue arises at the doors.
    Sphere | Sep 18, 2004 10:21pm | #1
    add a back band for the trim..say a 1x4 on EDGE next to the side of the window..rip whatever width ya need.
  2. csnow | Sep 20, 2004 06:46pm | #2
    You can attain a somewhat thinner rain screen by using long strips of felt or sticky membrane at each stud instead of wood furring strips.  This gap is adequate for a drainage plane.
Versatile Vise
