Resize Beam
tkiser | Posted in Construction Techniques on September 11, 2003 01:47am
We are building a new house and the plans call for a W8x18.  Beam length is 62′ max span is 13′-6 1/2 O.C. an the shortest span is 7′-10″.  Does any one know what size beam we can go with to eliminate some columns?  We are useing ICF (Insulate Concrete Forms) so we could use a taller beam but we don’t want to go too high.
I almost forgot, Ranch house non-load bearing interior walls, 32′ wide
Tim Kiser
Edited 9/10/2003 6:50:17 PM ET by tim
  1. Piffin | Sep 11, 2003 02:33am | #1
    Sorry, it'll have to be re-engineered by somebody qualified with the plans in frojnt of him/her
  2. HammerHarry | Sep 11, 2003 02:56am | #2
    You would have to have the plans with all the flooring and walls laid out, so that someone could do the calculations.  Should be someone who knows what they are doing.
    1. junkhound | Sep 11, 2003 04:44am | #4
      Even as a rabid DIY I'd need to go with the pro's advice on this one, the "details"  given say nothing except somebody hasn't a clue what's involved, plus as implied in previous response, that loads gotta go somewhere, like footings, etc, etc. etc.
    BossHog | Sep 11, 2003 04:44am | #3
    Ditto what the other guys said - Someone needs your plans to figure out the answer to that question.
    Try going to the lumberyard you plan to buy materials from. Ask them where they get beams from, and if the supplier will size them. Then see what you need to do to get the changes approved by the local building department.
    There are a number of mechanical devices which increase sexual arousal in women. Chief among these is the Mercedes-Benz 380SL.
    tkiser | Sep 13, 2003 03:57pm | #5
    I found out that we could use a w8x31 15'-6" O.C. Thanks
    Tim
    1. Piffin | Sep 13, 2003 04:39pm | #6
      That sounds reasonable for one story.
Shoulder Your Buckets
Add a strap for easy carrying and pouring when working with 5-gal. buckets.
