restoration of old wooden windows
lorraine morton | Posted in General Discussion on May 13, 2011 02:51am
I am remaking some 100 year old fir wooden windows and want to separate the mortise and tenon, how do I soften the glue?  With thanks, Lorraine
  1. DanH | May 13, 2011 10:58pm | #1
    Nine times out of ten you don't need to soften the glue -- it's all washed away anyway.  Otherwise, heat (eg, a hot air gun) is probably your best bet.
  2. DianeA | May 20, 2011 02:08pm | #2
    Steam Box
    You could go with a DYI steam box that could help with the old glazing, paint and should also help with the joints.  Check this link below.  There are some vids that provide an overview
    http://www.oldewindowrestorer.com/steamcabinet.html
    Diane
    hammer1 | May 20, 2011 04:54pm | #3
    100 year old windows were not glued. There are two wood pins holding the M&T. They might wiggle out or need to be drilled.
