Resurfacing stucco
Planeman | Posted in General Discussion on June 15, 2006 06:47am
I am having several windows replaced and new larger windows installed, of course this results in lots of stucco repair.  So…while I’m at it I want to “smooth out” the existing stucco.  It is currently a very rough, Spanish style finish, looks like a lemon merinque (sp) pie finish.  Is there a resonable way to grind or scrape off the rough finish and then have the surface all done at once in a smoother finish?
If I could actually be so honored to get one of the stucco contractors I have left numerous messages with to call me back, I would ask them, but in the meantime I will bring my question here.  Thanks for the help.
Experienced, but still dangerous!
  1. peteshlagor | Jun 15, 2006 03:35pm | #1
    When I lived n your neck of the woods, I found a great restucco-er out of Escondido.  However, he had a fairly bad stroke so's I imagine he's not available any longer.
    The guy I used after him was a lousy businessman and his work wasn't much better.
    But either way, they're awfully expensive.
    They don't grind or smooth out the stuff.  They completely remove it (down to the felt under) to be sure the moisture barrier is effective - especially after working around windows.  The final thickness needs to be 7/8"
    Don't forget the weep screed at the bottom.  Likely you got's some critters buiding condos down there.  Especially since S. Cal homes all have this lush growth at the base of the house.
    Five years ago I was hearing talk about shortages of sand for stucco in S. Cal. as I finished my job.   What's the current supply?
    1. Planeman | Jun 15, 2006 06:21pm | #2
      I haven't heard of any supply problems, hopefully that won't be an issue.  Stucco has always seemed like an odd choice in earthquake country, but with the voracious termites, sometimes it's only the stucco keeping the roof up!
      I was hoping to avoid removing all the stucco, but it would be a good idea to get a look at the framing and ensure that the moisture barrier is still intact.  The home was built in 1974, no telling what is lurking behind the stucco.
A New Approach to Foundations
