I would like to retrofit some casing in my home. the casing that I want to use is 1.5 inches wider than the existing. Is there any way that I can tie it into the existing base without removing the base. i.e., How do I cut into or modify the base?
There are some interesting ideas to a similar problem in "cut baseboard on wall" thread below.
