Retro-fitting Double Doors
DonCanDo | Posted in Construction Techniques on June 9, 2009 06:13am
I’ve installed many doors (pre-hung and retro-fit), but now I have an opportunity to install a set of double doors.  It seems like it would be pretty straight-forward to do pre-hungs, but I’m not sure how to install  them when the jambs are already in place.
My first thought was to leave the jambs, install the doors with tight clearances and then trim the doors if necessary.  That still leaves me with the challenge of keeping the doors “in plane”.
Now, I’m thinking that it might be easier to just pull the jambs and install pre-hung.  The downside is extra work to re-install the casing, possible drywall repair and re-painting, but overall, it might be a lot less grief.
  1. doorboy | Jun 09, 2009 06:30pm | #1
    They can be a challenge. I would first carefully check the fit of the existing doors. Then check the frame and confirm that it is PLS--"plumb, level, and square."
    If it is PLS, then your existing doors make good patterns for the new doors.
    1. DonCanDo | Jun 09, 2009 06:37pm | #2
      Thanks, but there are no existing doors.
      There's only a pocket door which no longer works.  The customer and I both agreed that it wouldn't be worth the effort to open up the wall to repair/replace it.
      P.S. I never knew that PLS stood for plumb, level, square.
      1. Dave45 | Jun 10, 2009 01:05am | #6
        FWIW, it's pretty easy to get a pocket door out of a wall. Figure out which side will let you get at the wheels, then remove a 10" - 12" strip of drywall across the top. I do this with a drywall saw and - if I work carefully - can usually save the piece(s) of drywall.Once you can can get to the wheels and track, you should be able to work the door out for removal. Working thru the opening, you can remove the old track and install a new one. Use the old drywall as a patch over the hole, install a new door and wheels, and you're good to go.
        1. DonCanDo | Jun 10, 2009 01:15am | #8
          I can picture exactly what you write, thanks.
          It's really cheap hardware so it wouldn't be worth replacing it with the same.  And besides... (doesn't it always seem the the "and besides" reason is actually the real reason?)... the customer doesn't want to deal with a pocket door anymore.
          Here's a tip back at ya: when I plan on re-using the piece of drywall that I'm removing, I use a multimaster.  Less dust and a perfect fit.
  2. Shep | Jun 09, 2009 06:47pm | #3
    Make sure the new doors are truly in wind. If they're not, it won't matter what the jamb is like; it'll be very difficult to get them to meet in the middle.
    1. DonCanDo | Jun 09, 2009 08:13pm | #4
      Thanks for the correct term "in wind" rather than "in plane".
      1. Shep | Jun 09, 2009 10:17pm | #5
        No problem.
        But don't get me started on guys who use the word "level" when they mean "plumb"
  3. mike4244 | Jun 10, 2009 01:11am | #7
    Usually I would say leave the jambs and mortice and hang the doors. But as I read your next post you have an existing pocket door.The double wall is weak to begin with because of the pocket door split studs. I would rip out the old jamb and install new 5/4 jambs with the hinges premorticed.Then you can hang your doors. Make sure the  head jamb is dead level. Keep both side jambs off the floor so you can shim for height. This is important with double doors. If the jambs must touch the finished floor then do not pre mortice the hinges on the jambs.
    mike
Eichlers Get an Upgrade
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
