Rewire Bandsaw for 220V?
corrib | Posted in General Discussion on August 13, 2007 10:03am
I’ve been fortifying my shop the last few months with some new tools and upgrades.
One of the upgrades I’ve considered was rewiring my 1.5HP Jet Bandsaw for 220V. I know about motor ratings and Tawianese tools, so I realize the saw might not actually be 1.5HP.
However, wouldn’t 220 make the motor run more efficently, (i.e. less heat produced)? Does a more effcient motor translate to more power?
Changing the plug and moving a couple wires in the motor doesn’t seem like a big deal.
But, I’m also from the school of “if it ain’t broke”.
Any thoughts?
Patrick
  1. JohnD1 | Aug 13, 2007 10:33pm | #1
    First--I am assuming that the motor shows how to wire the motor for 220 V.  If it doesn't, you of course can't change the operating voltage.  I rewired my table saw and dust collector for 220 V.
    Does the motor create less heat on 220V?
    ANS: No.  The same total current flows in the coils.  At 110 V there are two coils connected in parallel.  At 220 V the two coils are connected in series, so each has 110 V across it.
    Is it more efficient?
    ANS: Sort of.  220 V uses lower current, so the losses in the building wiring are lower.
    1. DanH | Aug 13, 2007 10:35pm | #2
      And, as a result of the lower current, it'll generally start a little faster and not stall as easily.
      1. junkhound | Aug 14, 2007 02:07am | #3
        Slight clarification for lower priced motors -- it starts faster because the current in the start winding is HIGHER on 240 than on 120.  Most low priced dual voltage motors provide only a SINGLE 240 V start winding, hence, the pathetically slow start at 120Vac, as only 1/2 voltage (hence 1/2 current and 1/4 the start winding power) is being applied to the start winding.
  2. corrib | Aug 14, 2007 05:36pm | #4
    It would seem that with the exception of the stalling, I probably wouldn't be gaining that much in rewiring.
    Would the motor last longer with the higher voltage and easier starts?
    1. DanH | Aug 14, 2007 06:26pm | #5
      The advantage would be most noticeable if your shop were some distance from the service entrance, causing voltage drop to be significant. It would also be helpful for a device that was marginal on a standard 20A circuit.
      1. corrib | Aug 14, 2007 06:42pm | #6
        Dan,
        Thanks for info! You've always been helpful with my various electrical questions.
        After all of the info shared here, I think I'm going to leave well enough alone. The saw has it's own 20 amp circuit and I've not had any problems...
        So, when I get my new 5hp SCM bandsaw, I'll be sure to post an ad for a lightly used 115V Jet 16" bandsawsaw on Breaktime.  Based on my controller's (aka girlfriend) budget, it might be a little while. Personally, I think a new Italian bandsaw would make a great engagement present from me to her.
        Thanks again for the info.
        Patrick
        Edited 8/14/2007 11:44 am ET by Corrib
  • Tall Deck on a Sloped Lot
