ridgid circ saw depth
collarandhames | Posted in Tools for Home Building on May 31, 2008 06:21am
Looking for help.  I’ve had  my 7 1/4 circ saw for several years.  The depth setting is pooched.  I was going to loosen off the mechanism and insert a brass shim to help with fastening the depth at large settings, ( was embarrassed by a fence cut this week— 🙂
Anyone have anyluck with similar units?  I can’t get the bolt to budge,, I guess I’m going  to look for my recipt and take it back!  Othewise it’s a good saw,,, done more than it’s fair share of use,,,,, I try to take it easy on low depth settings,, little miffed!
dave
  1. Smokey | May 31, 2008 06:28pm | #1
    I have a Rigid Fuego 6 1/2" circular saw.
    With it, all you need to do is remove the screw/cap that holds the lever on to the shaft.
    (a small allen wrench required in this case).
    Pull the lever off the shaft (there is a spring that comes off as well).
    The lever fits over a hex shaped spline. Rotate the handle one notch counter-clockwise back onto the shaft.
    Push the lever down and it should hold much tighter now. Reinstall the spring and the screw/cap.
    Most saws I have owned have the lever that is splined onto a shaft and you only need to rotate the lever counter-clockwise
    (for right sided blade anyway)a notch or two to tighten the depth adjustment.
    1. collarandhames | Jun 01, 2008 12:55am | #2
      Yeah,, I've adjusted those.  This one has a C ring on  a shaft and a nut.  I can't get the nut off,, so don't want to remove the c-ring.  Bit of a corker!  It has been such a great saw,,,,,
Podcast Episode 691: Replacing Vinyl Siding, Sloping Concrete, and Flat vs. Pitched Roofs
Listeners write in about ground-source heat pumps and weatherstripping and ask questions about engineered siding, concrete that slopes the wrong way, and why houses have pitched roofs.
  • A Postwar Comeback
