I’ve had to drill a lot of holes recently for wiring where my drills didn’t fit. I bought a Vermont American right angle attachment for my drill. It worked OK. Unfortunately, I ended up bending the shaft on it when the drill bit got stuck in a joist. I’ll see what Home Depot can do for me since it bent pretty easily. Here is the one I got:
<image attached since link wasn’t working>
I need to drill in tight spots, ie between studs, joists, in the attic, etc. I’ll be running some network and coaxial cable soon. I’m looking for something that also has an auxiliary handle for stability.
Do you have any recommendations for a quality right angle drill attachment.
Does any have experience with this Craftsman drill? It’s not too expensive (I can’t justify the larger dedicated right angle drills from Milwaulkee, etc.) Image attached.
Rigid has a small, right angle impact driver. It looks nice but I’m hesitant to buy yet another battery operated tool that I have to worry about keeping charged.
http://www.ridgid.com/Tools/R82233-Right-Angle-Impact-Driver/index.htm
Edited 7/22/2005 9:42 am ET by Thang
Edited 7/22/2005 9:43 am ET by Thang
Edited 7/22/2005 9:47 am ET by Thang
Here is the Vermont American right angle attachment.
I had that same VA angle attachment & it is a piece of junk.
Fortunately I didin't have to drill tons of holes, so it lasted through that job at least. I'd definitely look into the milwaukee RA attachment if you are going to need it on a regular basis.
Killler rig at Lowes.... Its called the orbiter, you can drill any angle you want. Attaches to your drill. $30
-zen
Saw the orbiter...was wondering if it was another piece of crap or not. I guess there's only one way to find out. The hex shaped shaft should make stripping less likely. That's what happend to the Vermont American one I have. The chuck started to strip the shaft and then it got so thin it bent. The Milwaulkee dedicated is too expensive. Even if I could convert it to a normal drill/driver, I already have 2 corded models. The Milwaulkee right angle attachement looks pretty solid; checked it out today at Home Depot. My concern with that is that its small size would make it hard to hold it steady. The need to buy a seperate chuck to hold larger drill bits would be a minus too. I guess for now it's the orbiter...although, the small 12 volt Makita impact driver looked nice too.
Thang,That Milwaukee right angle attachment you refer to is only rated for 235 inch-pounds. Many 12 volt drills can exceed that, so it is not the rig for drilling any but small holes. I had their earlier one, which looked similar, but different side handle. Lame. And expensive, too. I returned it, if memory serves.Bill
This is rated for 500 lbs. I use it more often than not when remodeling my house, I'm quite happy with it.
"This is rated for 500 lbs. I use it more often than not when remodeling my house, I'm quite happy with it."That's a little better with side handle. However, it still takes hex shank bits. My auger bits wouldn't fit...and I've really learned to hate spade bits.
I've used these with 1/4" and 3/8" auger drill bits and it worked fine. Not so much with 1/2" though....http://www.coastaltool.com/cgi-bin/SoftCart.exe/a/ab/snappy/drill_bits.htm?L+coastest+rzlj7814ff204220+1122388768
Take a closer look at the tool stores or online and you'll see that Milwaukee has come out with another HD version of their original $25 right angle screwdriver attach.Seems tho me it was rated for up to 4-500 pounds, cost about $50.I have the original $25 version, and it's only really good as a screwdriver attachment.I use a Makita 9.6 volt angle drill and for most everything it works very good. Not for drilling through joists or anything, but then, I can't imagine any VA attachment being able to do that anyways...JT
I saw a Rt angle attchment made by the same company as the orbiter at Rockler yesterday if that suits you better.
-zen
My concerns with the Milwaulkee right angle attachment are:
1) small size makes it hard to hold steady
2) no side handle (definitely need this to steady the drill
3) the hex shaped shaft holder (for driver bits) makes it a pain to attach large drill bits. I use a set of self-feed auger bits for the drilling. They need a real chuck.
You might want to check out this product from Milwaukee. I'm going to pick one up soon because I don't really need a dedicated RAD, but for $50 this thing looks like the ticket.
http://www.milwaukeeconnect.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=27&catalogId=40027&langId=-1&mainCategoryId=362&fromSearch=Y&productId=329656&parentProd=329655
Sorry for the long link, and if it doesn't work just look up model number 49-22-8510. It's listed under accessories I think.
Ryan
You can get that for about 25 bucks most places.
I have one of those Milwaukee attachments - it's OK for little stuff, but as stated above is kinda of light duty. I've used it for assembling railings and stuff like that, but I doubt that it would be appropriate for drilling joists - as the original poster was talking about. Matt
Is that attachement different than what they have on the right angle drills? The drills they sell several version as plumbers kits and electricans kits so they are expecting heavy usage.
Nothing at all what would be on a milwalkee drill Look at the picture again:
To give you a reference as to the scale of the thing, the shank that fits in the drill is a standard 1/4" hex. I'd guess that the whole tool weighs less than a pound. Definately not heavy duty. Like someone said above - definately more of a screwdriver attachment (which is mostly what I got it for).
BTW - the drill I see most electricians and plumbers using are Milwalkees, and more often than not, a hole-hog.
Matt
Edited 7/24/2005 12:01 pm ET by Matt
I never looked at the picture.I think that at one time they sold the right angle part these drills separately and that it was I was thinking of.http://www.milwaukeeconnect.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=27&catalogId=40027&langId=-1&productId=281143&mainHeader=Drills%2FCorded&categoryId=189333&mainCategoryId=362In fact they sell an extension for use with the above drills or the RAD. But I could not find anyting under the part number that they listed so it must be discontinued.http://www.milwaukeeconnect.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=27&catalogId=40027&langId=-1&productId=284037&mainCategoryId=127418&secondRefNum=189284&thirdRefNum=189284&firstHeader=Accessories&secondCatName=no&subCategoryHeader=no&thirdCatHeader=Adapters&fromCatalog=Y
Really handy and popular tool
http://www.mytoolstore.com/milwauke/0375-6.html
Here is an alternative from Milwaukee:
http://tinyurl.com/c4m2k
While it is sold as a right angle drill, you can easily remove the right angle attachment and use it as a conventional drill.
We use this drill for all our right angle work, and it works great with a self-feed bit for any electrical work you will encounter and most plumbing tasks.
It is not as powerful as the dedicated right angle drills, but it will get the occasional job done just fine.
However, it costs somewhere around $220, so it would make sense only if you could make use of it as a conventional corded drill.
"I tend to live in the past because most of my life is there."
-- Herb Caen (1916-1997)
If you are looking at a dedicated cordless tool, take a look at the tool next to that Ridged at HD. I actually own this and the tool you pointed out:
Edit: Go here http://www.ryobitools.com/product/index.asp?sectionid=1 and look in cordless drills for the picture. They must not allow outside links to the pictures.
SPECIFICATIONS:
• Battery: 18 volts
• RPM: 0-1,000 (no load speed)
• Chuck Capacity: 3/8â€
• Net Weight: 3.0 lbs
FEATURES:
• Compact right angle design allows you to get into tight spaces
• Extensive power grip overmold maximizes user comfort
• Oversized trigger for various hand positions
• 3/8 †Heavy-duty ratcheting chuck for quick secure bit changes
• Variable speed switch controls drilling/driving from a slow start to a fast finish
• Forward/Reverse selector conveniently located for inserting and removal tasks
• Swiveling foot allows you to position the battery pack in the most convenient location
• On-board bit storage for quick storage and access
INCLUDES:
• P240 Right Angle “Close Quarters†Drill
• P920 Plug in Lanyard
• Battery and Charger Sold Separately
Also a CRX fanatic!
Edited 7/26/2005 12:50 pm ET by xxPaulCPxx
Do you have a pic? I'm getting a blank placeholder.
