Rigid foam exterior and batt interior vs close cell spray foam
Wedge18 | Posted in General Discussion on August 8, 2019 10:11pm
I’m pricing out insulation for my renovation and it is about the same for 1 inch rigid foam exterior with R15 batt insulation in the stud bays and R20 closed cell without the rigid exterior foam.
I can decide which is better. I’m leaning towards the rigid plus batt but would like to hear some thoughts.
  1. bwsct | Sep 12, 2019 10:25pm | #1
    Checkout the Green Building Forum. They'll have an opinion on this.
  2. bcinvt | Sep 14, 2019 11:24pm | #2
    It all depends on how carefully each choice is installed. There is a lot more detail to address using the batts with exterior foam as far as getting good air sealing. A good layer of spray foam is likely to seal better with an experienced installer. But there are different environmental costs to each choice .
    The Green Building Forum is worth looking at for more details, but the choice really depends on you.
  3. MattMillham | Sep 16, 2019 02:26pm | #3
    There's a bit of science that goes into knowing how thick the exterior foam has to be to prevent moisture from collecting in the sheathing. 1 in. may or may not be enough. To answer your question, we need to know what climate zone you're in.
    1. Wedge18 | Sep 19, 2019 08:38am | #6
      I decided on spray foam more due to the confidence I have in my GC on installing spray foam vs rigid exterior insulation..
  4. RussMill | Sep 18, 2019 09:03pm | #4
    Foam between studs is almost a waste. Exterior foam works much better. What climate zone are youbin?
    1. Wedge18 | Sep 19, 2019 08:29am | #5
      I'm on the border of zone 4 and 5. I decided on spray foam more because of my confidence in the GC to correctly install the rigid exterior foam correctly. I know I would end up with a better result with the exterior insulation as long as it was fine right but I was too worried about water and moisture issues.
  • Smarter Stop Block
  • Square Walls Solo
