Rigid foam exterior insulation
patmando | Posted in Energy, Heating & Insulation on October 22, 2008 08:05am
I’m planning on installing foil backed rigid foam insulation to the outside of my new construction 2×6 OSB sheathed house as described in Fine Homebuilding’s “Save Energy with Rigid Foam Insulation” 2007. This article describes in some detail how the rigid foam is applied except it doesn’t go into any details on window and door flashing or if a house wrap is needed. Does anyone have any experience with this and would be able to advise me on how to handle these issues?
Thanks.
Podcast Episode 691: Replacing Vinyl Siding, Sloping Concrete, and Flat vs. Pitched Roofs
Listeners write in about ground-source heat pumps and weatherstripping and ask questions about engineered siding, concrete that slopes the wrong way, and why houses have pitched roofs.
  • A Postwar Comeback
