Would you guys recommend rigid foam insulation over my osb sheathing (with felt) and under hardi? Being in Texas would it help?
no
Mike,Are you concerned about vermin or vapor?
vermin, vapor, nailbase under the foam instead of on top of the foam,
lack of blocking for trim........
exterior foam sucks
'course, that's just my opinionMike Hussein Smith Rhode Island : Design / Build / Repair / Restore
Thanks for the input Mike.
To be a devil's advocate (or maybe just a pain), he could use borate treated EPS (vermin), EPS has a perm rating of 2-5 in 1" thick and he's in a cooling climate so a VB on the exterior may not be a bad thing, and Hardie says you can install their siding over 1" foam.'course, that's just my opinion.
Hardie says a lot of things i disagree with..
they are marketer's trying to expand their market
for instance... they want a 2" gap between the bottoms of their siding and any horizontal surface
way excessive
also.... there is a ton of trim on an exterior
attaching trim over foam with out blocking is asking for troubleMike Hussein Smith Rhode Island : Design / Build / Repair / Restore
But mike, if he takes the advice you gave me it can work.
You advised me to install blocking before the foamboard. Although it is additional labor and material it worked out just fine. I even added a layer of house wrap over the blocking as a weather barrier and tapped it to the foam board.
It is now ready for the trim and feel comfortable with the weather tightness and added insulation value I have achieved. The windows were set on the blocking so everything will plane out to a normal siding install.
To the OP.
You will also need to add interior jamb extension to both doors and windows.
Thanks guys for all your input.
If you have any window or door leaks the water will get trapped between the foam and the OSB and will cause a major rotting problem very similar to the EFIS problems that are still on going. In my opinion, every house will have leaks from time to time so you want to plan for a way to drain the water and allow it to breath to dry out.
Thanks T.
Wrinkle wrap behind the foam and over the blocking for windows, doors, and trim.
My garage has been sitting since last December, just that way. Windows and doors are installed and properly flashed. I have kept a close watch on the sheating, windows and doors from inside all winter. we have had some pretty good wind driven storms durring that time. Thus far there are no signs of any leaks.
I think his idea is doable with carefull detailing
I had an EFIS home and I am a builder. I can tell you that all homes have small leaks from time to time that you'll never see or notice. But if water gets trapped you will have rot and maybe termites and the resulting problems may not show up for many years.
My foam is a minimum of 8" above grade on a concrete foundation. I used a tern flashing beneath the house wrap and stepped out and down over the foundation wall. My goal was to have a continouse drainage plane behind the foam and create a termite shiled at the lower edge. Of course there is no such thing as a temite shield, but at least it forces the little buggers to build thier mud tunnels out where you can see them.
As far as all houses developing leaks. That is a possibility that depends a lot on the care and skill of the builder IMO. Thing don't just happen over time. Something fails or was not right to start with.
Well when a house goes through a storm event: hurricane, noreaster, etc. then you will probably have some water pushed uphill and into places you never thought of. Thats what I mean when I say all houses will leak somewhere sometime.
Edited 3/30/2009 6:29 pm ET by T White
Done all the time just up the road from you. Have not been enough in Travis or Williamson Cos. lately to comment on practices therein.
It's usually the sheapest way to pass ResCheck using a stock plan. And, in the massive thermal gain climate we are in, a thermal break on the outside of the framing makes a great deal of sense, too.
Thanks Cap.
Google: Read This Before You Design BUild or Renovate. It has assemlies such as you describe. There are many other publications that deal with this, some you will have to buy.
buildingscience.com
I think foam outside of the sheathing creates more problems than it is worth in R value.
Done all the time here in NY. Did 3/4 " Tuff-R w/ Hardi 4+ years ago on mine, No problems,Just pay attention to all flashing details!!! Get the extra R value Oil not getting cheaper down the line
NY is NOT Texas.
Totally different.
Thanks for clearing that up
