rigid insulation on curved wall
aulia | Posted in Energy, Heating & Insulation on January 4, 2006 12:34pm
I’ve got a block-stucco interior wall with a curved corner approx 5-foot radius
How the hell to fasten 2″ of styrofoam (blue) ??????  I can just see the glue coming loose one day  🙁
I’ll mesh & plaster once its up there.
TIA
  1. tab1 | Jan 04, 2006 05:12pm | #1
    One option might be to use 1/4, or 1/2" if flexible enough, layers and build/glue them up successively until you've got the thickness you need.
  2. Winchester | Jan 04, 2006 05:34pm | #2
    Inside corner or outside corner?
    I would cut the board into vertical panels with beveled edges- kind of like coopering a barrel.
    1. aulia | Jan 04, 2006 06:12pm | #3
      Thanks,
      It's an inside corner.  I'm just leery of depending on glue for the long haul.
      I was considering using 2 layers of 1" and 3/16" plywood.  Then driving ramset nails into the block.  assuming the 1" will bend enough.
      Or maybe leaving gaps in 2" strips & filling with urethane foam?
      Aulia
      1. Winchester | Jan 04, 2006 07:41pm | #4
        Filling the gaps with urethane foam sounds like a good way to go, then rasp off the excess.
        Good luck.
