rigid or sprayed in closed cell insulation?
haw1 | Posted in Construction Techniques on September 23, 2011 09:11am
We’re still trying to figure out what would be the best approach for insulating the dormer section of the roof (with 2×6 rafters).  Once we get the proper vents in the correct place, would it be best to use 2 or 4 inch rigid insulation or have an insulating company come in and spray the closed cell foam?  Do we need proper vents if we go with the 4 inch rigid?  There would be a 2 inch gap behind it.  I haven’t done enough research on the closed cell sprayed in foam to understand how that is applied in a ceiling.
Thanks,
haw1
