Ring shank or smooth nails?
robbyve | Posted in Construction Techniques on May 3, 2023 07:03pm
Hello guys, I will nail a 23/32 subfloor and I  have a lot of  2″ smooth nails available. Would they be ok to use, or would I have to buy some ring shanks? I also will add glue. Thanks for your suggestions.
  1. calvin | May 04, 2023 03:37pm | #1
    If it were me, I’d glue and screw it down.
    But I do have a stand up and collated screw gun and have had to repair/replace even a glued and nailed down subfloor several times in 50 yrs.
    1. robbyve | May 04, 2023 06:13pm | #2
      Thank you Calvin.
    saraclover | May 04, 2023 06:35pm | #3
    Smooth nails can be used for nailing a subfloor, but it is recommended to use ring shank nails as they provide better holding power. Adding glue will also help ensure a more secure installation.
    1. robbyve | May 05, 2023 11:47pm | #4
      Thank you Saraclover.
  3. jimmiem | May 06, 2023 08:40am | #5
    Why take a chance on the nails? Seems a lot easier to install screws with an impact driver than hammer a ton of nails. I've used SPAX screws (no predrilling) to secure squeaky sub-floor and replace loose nails.
    1. robbyve | May 07, 2023 12:22am | #6
      Thank you jimmiem, I had the nails for the nail gun, but screws sounds holding more than anything else.
  4. MrSimon | May 07, 2023 05:44am | #7
    Ring shank nails have rings or ridges along the shank, which create greater resistance to pull-out and increase holding power. This makes them ideal for applications where the wood may expand or contract, such as in framing or decking. The rings help keep the nail securely in place, even as the wood shifts.
    1. robbyve | May 13, 2023 01:38pm | #8
      Thank you MrSimon!
  5. davidoliver | May 16, 2023 07:00am | #9
    The choice between ring shank nails and smooth nails depends on the specific application and the desired result. Here's a brief comparison of both types:
    Ring Shank Nails: These nails have rings or spiraled grooves along their shank, which provide enhanced holding power and grip. The ridges of the ring shank create friction that helps prevent the nails from pulling out easily. Ring shank nails are commonly used in applications where strong holding power is required, such as framing, decking, and other structural work.
    Smooth Nails: Smooth nails have a plain, smooth surface without any ridges or grooves along their shank. They are suitable for applications where holding power is not the primary concern, such as finish carpentry or projects where the nails will be concealed, such as furniture assembly. Smooth nails are often used in trim work, cabinet installation, or other decorative applications.
  6. BuildWithCapri | May 17, 2023 01:06pm | #10
    We generally glue & screw on our kitchen & bath remodels.
