Rip fence for Ridgid Worm drive?
xxPaulCPxx | Posted in Tools for Home Building on March 15, 2006 06:29am
I realized that my nifty Ridgid saw didn’t come with the adjustable Rip fence.  HD doesn’t seem to stock it, and the other brand I saw on the shelf was a little too wide.  Does anyone know of a different brands fence that might fit?
Also a CRX fanatic!
  1. kostello | Mar 15, 2006 10:49am | #1
    i didn't realise anyone used those things.
    with practice you can get a good straight cut by using your thumb as a guide on the saw base and fingers in the egde of the timber.
  2. pagoda | Mar 15, 2006 11:38am | #2
    If hd has it in their " special order catalogue " they will send it  by courier to your door , usually about a week for delivery  or call ridged "tech support " to make sure it exists (1 -800 4 ridgid)
  3. RedRobertson | Mar 15, 2006 01:10pm | #3
    I've drilled holes in the plate of my DW circular saw so I can mount it to the underside of a piece of plywood and make a quick tablesaw in a pinch.
    Maybe you can do the same to mount an extension.
    Doesn't seem right, xxPaulCPxx, gets screwed by HD.
    1. philarenewal | Mar 15, 2006 02:39pm | #4
      Red:
      You mount that saw with screws or nut & bolt?  Nails?
      Just showing I'm paying attention.  ;-)
      "A job well done is its own reward.  Now would you prefer to make the final payment by cash, check or Master Card?"
        xxPaulCPxx | Mar 15, 2006 07:33pm | #5
        No man - STAPLES!  Really, you have to pay closer attantion ;)Rebuilding my home in Cypress, CA
        Also a CRX fanatic!
      2. RedRobertson | Mar 16, 2006 05:02am | #7
        drill 3/16" holes into corners of circular saw base
        3/4" #10 round head Robertson screws times 4 into 3/4 ply
        drop blade through plywood
        wrap a piece of wire around trigger
        flip plywood onto saw horses
        screw scrap of ply for fence
        use switch on power bar for on/ off
        cut the few feet of needed baseboard, trim etc
        Red
      xxPaulCPxx | Mar 15, 2006 07:39pm | #6
      That is a good possible solution if the fence isn't available.
      I need to shave a 1.5" x 1/8" notch into a bunch of 2x6x20'ers.  I was setting up my tablesaw, but was getting real nervous about launching a 2x6 missile if it got bound up on the blade.
      Cute :)Rebuilding my home in Cypress, CA
      Also a CRX fanatic!
      1. RedRobertson | Mar 16, 2006 05:12am | #8
        1½" X 1/8" notch in 2X6?
        Just pinch the edge of the sawplate and use your knuckle for a guide.
        or C clamp a block to the plate.
        If you ever have to make the same trim cut by hand in pine or hardwood?
        Power plane
        Red
        1. MikeSmith | Mar 16, 2006 05:16am | #9
          get yourself an EZ-Guide, you'll wonder how you got along without  one all these yearsMike Smith Rhode Island : Design / Build / Repair / Restore
        Bluemoose | Mar 16, 2006 05:25am | #10
        I think I might just use a sharp chisel.
