ripping pressure treated lumber
rfarnham | Posted in General Discussion on December 23, 2009 11:43am
Does pressure treated lumber lose its rot resistance when you rip it? When I rip a piece of PT lumber you can see that the green color has not fully penetrated the wood. I don’t know if the color is the same as the rot-resistant treatment. Am I exposing untreated portions of the wood and negating the effect of the treatment?
  1. Mike_Mills | Dec 23, 2009 02:03pm | #1
    Yes, you are. You have to spot-treat the newly exposed wood.
    1. rfarnham | Dec 23, 2009 04:25pm | #2
      That's what I was afraid of.
      That's what I was afraid of. Thanks.
  2. JTC1 | Dec 23, 2009 05:10pm | #3
    Is this SYP or another species?
    If SYP, a color shift indicates a manufacturing problem / defect. The point of PT process is to penetrate the full thickness of the lumber - thicker the board, longer the pressure treatment.
    PT SYP is the same color throughout the thickness.
    This would also indicate that every crosscut will expose untreated wood - not just the rips.
    I smell a rat and would return the lumber.
    If a species other than SYP, my comments may not be valid.
    Jim
  3. MGMaxwell | Dec 23, 2009 07:02pm | #4
    Depends on the strength of the treatment. Most is .25 but salt water treatment is 2.5 [been a long time since I used salt water treated so don't hold me to that]. The higher number is higher concentration and deeper penetration. You can still get CCA here for salt water applications. Most demensional lumber is .25 or .40 which is ground contact I believe.
  4. TomT226 | Dec 24, 2009 06:37am | #5
    SYP ACQ surfaces will turn darker in sunlight than the interior. I cut some 6X6 ACQ the other day and it was somewhat green all the way through, so the penetration must be pretty good. Pulled some treated posts out of the ground last week that had been there ten years, and they were stll sound.
    1. DanH | Dec 24, 2009 08:40am | #6
      But I've seen many a piece of
      But I've seen many a piece of treated wood that was solid on the outside and rotten on the inside.
  5. Ingleton1 | Dec 24, 2009 08:52am | #7
    I have worked with pressure treated wood for almost 20 years and have rarely found many pieces with the treatment fully penetrated through the wood.
    Your lumber retailer will sell a product (usually a pressure treated green preservative) that you are supposed to brush onto any of your cuts to meet the warranty of the pressure treated product.
    1. calvin | Dec 24, 2009 08:58am | #8
      I have found here in NW Oh. that products available are minimal. Cuprinol used to have a decent product for treatment of cut ends. VOC regs I think have limited those that are available.
      In addition to treating cuts I'd smear tar on cut ends in the ground.
      One of the many reasons I dislike building decks.
