Rocking Toilet Install
Tad2 | Posted in General Discussion on July 7, 2008 04:53am
OK, I am installing a new toilet, in a new bathroom, and the toilet has an annoying side to side rock.  This rocking appears to be from the tile floor, not the WC.
I know I can put a couple of shims in to fix this, but I was wondering if I can grind with a hand grinder  the interference spots on the toilet itself, to match the floor?  If so, any recomendations on wheels, or what kind to avoid?
Thanks!
    IMERC | Jul 07, 2008 04:58pm | #1
    you will break that toilet if you try that...
    fix the tile, grout it or shim it..
    WOW!!! What a Ride!
  2. brucet9 | Jul 07, 2008 06:24pm | #2
    You have the right idea about grinding, but work on the other side of the problem. Use a diamond blade on an angle grinder to cut away the tile under those interference points. If they are small tiles, you can avoid the dust by cold-chiseling out the offending tiles.
    BruceT
  3. mike_maines | Jul 07, 2008 07:42pm | #3
    You might also check that the toilet flange screws are fully tightened.  At least once I've found that to be the source of the problem.
