Rockwell Jawhorse
emaxxman00 | Posted in Tools for Home Building on October 18, 2009 10:59am
Does anyone have one of these?
http://www.rockwelltoolsdirect.com/jawhorse.html
It’s not for me. My dad does home renovations and asked for one for Xmas. It looks pretty neat and if it’s what he wants, I have no reason to not get it for him.
Just wondering what good uses you’ve found for it and/or if there are significant shortfalls that one should be aware of.
Thanks.
  1. calvin | Oct 19, 2009 12:06am | #1
    After reading about them here I finally got to see one in the general store here.
    To me, too much metal.  About as useful in the general way that the stanley workmate.  Sure, it can hold a saw, be a sort of vice, and is a small worktable-I'm sure I'd have lost the bench dogs almost immediately.  Some working friends I know have had the workmate for yrs, just never go into them myself.
    But, being the rockwell isn't wood........would preclude using it as a horse, tho it's shaped alot like one......I'd give some thought to making him a real nice set of horses and then buying him some nice clamps to do what the rockwell does.
    Be more personal.
    http://www.quittintime.com/
    Edited 10/18/2009 5:07 pm ET by calvin
  2. Pelipeth | Oct 19, 2009 02:26am | #2
    There are already alot of copy cats out there. I saw 3 or 4 variations at a local tool store this week-end, good quality and less money. I feel they will ALL nickle and dime you with the options. Check out
    toolnut.com. Weight and space may be a factor if one was to haul this around in a truck or van all the time.
    1. renosteinke | Oct 19, 2009 07:02am | #3
      The Rockwell IS the copycat; I own the original Triton. The two are essentially identical.
      I don't often need it, so the ability to fold it up and store it is nice. The times I have used it, it has been a big help.
      Don't think of it as a sawhorse. Think of it as a really big vise that doesn't need a bench. It compliments the work-mate tables ... for when you want to grab something smaller, or more firmly than the Work-mate can .... or, like they show with the door, something a lot wider than either a Work-mate or regular vise can grab.
      1. chairmon | Oct 19, 2009 07:10am | #4
        IIRC Rockwell purchased a license for North America from Triton It is built under Triton's patents.
        Craig
        1. emaxxman00 | Oct 19, 2009 09:25pm | #5
          I watched the infomercial on the website. The base package seems to be a sawhorse with a built in clamp. It seems like the true versatility requires a lot of the add-ons at an additional charge. I'll ask him what his main intent is. I wonder of a portable miter saw stand like the Rigid model is a better value. The Rigid is heavier and that may be a concern for my dad.
          1. renosteinke | Oct 19, 2009 09:32pm | #6
            Add-ons? I'll have to look into those.... OK, I just looked.
            I was aware of different jaws being available; the factory hard plastic jaws work fine for me so far. I certainly don't need the log jaws - though I might change my mind if I catch a thief on-site :D
            There was a little 'parts tray' offered, and that might be handy; I can probably cobble one together. I'm not so sure about the 'saddlebag' being useful; the main thing I have to set down is my tape measure.
            For very wide loads, it is the existing moveable jaw that comes off, gets reversed, and allows gripping something like a door across the entire width. The standard unit will get you to at least 30".
            The miter-saw stand is something you can easily make yourself. Still, for any but the smallest saws and lightest work, I'd want a proper stand.
            I can't speak to welding, though I have seen similar 'third hands' with magnetic bases - one of those would work just as well.
            As for the 'work table,'  I'll stick with the Work-mate, or set up a better table. Heck, a round piece of plywood over the trash can would likely do as well or better.
            I'd think pretty carefully as to how you plan to use it. For examle, I often need to put holes in large metal boxes. The vise lets me hold the boxes securely while I work.
            Edited 10/19/2009 2:42 pm ET by renosteinke
          2. emaxxman00 | Oct 21, 2009 04:14pm | #7
            My dad has a large 12 inch compound miter saw (not sure if it's a slider or not). He needs portability so a homemade stand probably wouldn't work. I have a dedicated, albeit heavy, miter saw stand from HD. I don't have to lug it anywhere so the the weight is not an issue. It's great to have when cutting trim.I'll ask my dad what he wants it for. I know he often works alone so the jawhorse may be a big help to him.
  3. Carpeater | Oct 21, 2009 10:19pm | #8
    If youw ant to see one in person check Home Depot or Lowes. Was in each last week and can't remember which one I saw the display.
