Rockwell (Sawbuck) Frame & Trim Saw
I’m probably shooting in the dark here but here’s the question… I have a old Rockwell frame & trim (sawbuck) #33-050.
I need to replace the arbor bolt (screw) for mounting the blade. Can anyone tell me the screw size? Diameter, pitch (thread) & length. I know it’s a left hand thread. Is it a Metric, English or special factory thread?
A left hand 5/16-24 seems just a little loose, could be it but would like to be sure.
Odd that Rockwell and Delta have the same model number for their "frame and trim" saw. The Delta uses a brass nut, apparently.
(Are you sure your model number isn't 33-150?)
Thanks for the reply DanH... yes 33-150. FINIALY found the Arbor Screw "no info. on the tread" just a part # to order.
Here's the scoop if it helps someone else Screw #422-25-112-0001 RENOVO parts .com $4.42 + shipping
ph.248-634-6234
