Rockwool fire retard vs. Ultra Touch?
ovolo | Posted in Energy, Heating & Insulation on September 25, 2007 10:44am
Does anyone know how ‘rockwool’ differs from some other ‘fire retardant insulations. In particular with regard to the MA building code.
We have an spot where the inspector wanted a solid fire block or rock wool. Its a chase that has many wires going through it. The cleint wants to use only Ultra Touch (recycled blue jeans) through the house. No fibreglass. UltraTouch is saturated with a natural fire retardant (borates) giving UltraTouch insulation a Class-A fire rating. I am not sure how that compares to Rockwool.
thanks all..
www.thesmallbuildingcompany.com
    xxPaulCPxx | Sep 25, 2007 11:08pm | #1
    What about foam fireblocking?  Great Stuff Pro in gun foam cans is an approved fire block.  It's bright orange so you can tell the difference with regular polyu foam.
    Also a CRX fanatic!
    If your hair looks funny, it's because God likes to scratch his nuts.  You nut, you.
  2. caseyr | Sep 26, 2007 02:15am | #2
    I believe that "Rock Wool" is a brand name for a type of mineral wool insulation. IIRC, mineral wool can be made from either furnace slag or naturally formed rocks - and maybe a few other things. The stuff is a lot like fiberglass insulation. It can also have irregularly shaped pieces in the insulation that are extremely sharp and can readily cut severely.
    I haven't had time to read these, but you may want to look at (among others):
    http://en.wikipedia.org/wiki/Mineral_wool
    http://www.naima.org/pages/resources/faq/faq_mineral.html
  3. grandchat27 | Sep 26, 2007 03:23am | #3
    Up in Canada, a company named Roxul produces a very good "rockwool" insulation.  It's completely water-proof, and I watched at a demonstration where they put a torch on the insulation for like 2 hours and nothing really happened.  Neither fire, nor water will affect this insulation's performance.  Also, it's extremely easy to cut, unlike the traditional insulation and it has a much higher r value (R16 vs. R12, etc..  I've attached a link for reference.
    http://www.roxul.com/sw16796.asp
