roof bath vent
bricktron | Posted in Construction Techniques on August 5, 2017 01:54am
hi folks, our bathrooms each have one window that open onto semi-enclosed light wells. odors and humidity stick around if the bath doors are closed, so we want to increase airflow. in-wall fans would be right next to the existing windows, make noise, and require a bunch of electrical work, so we haven’t jumped at the chance to install them.
what about venting upwards to the (hip and valley) roof? even a small a stack effect might do the trick. a wind-powered turbine is also a possibility. the location is central california and so a little heat loss is OK, though the turbine is probably excessive. i don’t have a clue how much cross-sectional duct area might address the problem. there’s no advantage to a vent near the floor, right? what do you all think?
  1. florida | Aug 11, 2017 02:08pm | #1
    I think if you'll install a 4" vent pipe through the roof connected to a small electric vent fan your problems will go away.
  2. user-6904308 | Aug 19, 2017 08:16pm | #2
    I had a simillar problem.   Then I saw a "This Old House" you tube video of Tom (I think) installing a bath vent fan through the attic and out the roof.  He used insulated flexible ducting.  I'm sorry I don't have the link, but it should be a quick find via Google.  Good luck.
