roof construction
| Posted in Construction Techniques on April 13, 2002 08:46am
I need to figure out how to build a barrell roof the dimensiois for the rooof itself is 9 feet 9 inches and 3/8(w) by 72 in and 1/4.  I am not sue how to go about figuring the cut for a barrell roof and looking for some help.  any help would be helpful and any more information needed just write and I will be glad to give it to you.  Thank You , Todd
  1. TerrySmiley | Apr 13, 2002 11:50pm | #1
    I'm not following your dimensions.  What's the radius, do you know or are you looking for help finding it?  Is it going on top of a building with the dimensions you listed.  Which dimension would be the gable end or end of the barrel.  I can help, I've built a lot of these and understand the lay out well, if you'll provide info.
    Terry
    Tabula rase
  2. MikeWillms | Apr 14, 2002 01:00am | #2
    Your radius is 59 - 15/16" I'd tack sheets of plywood on a wood subfloor to create one piece large enough to draw the segment, then cut it out with a jigsaw. If a round "truss" is required, cut multiple pieces and lam together staggering joints.
    918 Contracting - Residential Construction
