Roof Deck Post flashing detail
rjh | Posted in Construction Techniques on July 7, 2005 08:15am
I have an existing roof deck for which I need to add a deck railing supported by posts. The roof deck has sufficient slope for drainage and consists of a continuous waterproof membrane, lightweight concrete, and tile. The deck is flashed correctly and there are no water leaks. However, I still need to add the deck railing and posts. What is the preffered technique for attaching the posts to avoid water leaks now that the deck is complete?
My original plan was to drill through the deck into the roof framing and bolt the posts through a self sealing membrane located between the post base and the tile. However I spoke with an iron work (railing) sub-contractor, and he feels that metal post bases should have been embedded in the concrete before the tile went in place. He thinks my idea of attaching through a membrane is flawed and that the deck tile should be removed to embed the metal post bases. I am concerned that this amount of rework in itself could encourage water leaks. Any suggestions?
  1. rez | Aug 15, 2005 06:52pm | #1
    Greetings Rob-
    That subject has been addressed here on Breaktime a number of different times in the past.
    In the event you fail to receive the information you desire, you might find it in the archives.
    If you scroll down in the lower left corner of your screen there is a search function that will take you to previous threads dealing with whatever you type in the search bar.
    If you type in 'deck rail drainage'  or other keywords of the subject matter you'll get a supply of data from those old threads.
    Cheers
    A person with no sense of humor about themselves is fullashid
  • xoxo test post 3
  • xoxo test post 2
  • xoxo test post 1
