I have a low pitch roof over a den, and porch. Here in AZ it is on the warm side. My question: would like to install 6″ rigid foam, and reroof.
My question is: should i remove the existing roll roofing? or simply go over the existing roofing material?? The Fox.
This window installation system allows most of the work to be done from the inside, making the process faster and safer for one person working alone.
Just go over the existing, much better than starting from scratch, esp, if it isn't dripping .Wet. Or causing undue damage to the fixtures that are present.
Make a sweet noise, it might be the last sound you hear
