Roof Insulation systems for Timber Frame
JamesT | Posted in Energy, Heating & Insulation on July 26, 2004 07:42am
G’Day;
Constructing a timber frame, and still have not finalized roofing system… oh boy…
Options:
1. Structural Insulated Panels (SIP’s)
2. Built-up roof system
  • 2×6 T&G Pine decking screwed to horizontal purlins at 4 ft. centres
  • 6 inches of polyisocyanrate foam – 4″ + 2″ cross piled to stager joints
  • joints taped, edges foamed
  • 2×4 furring strips on flat, screwed thru to rafters & purlins
  • 3/4 T&G plywood top
  • ice & water membrane
  • standing seam steel roofing
Tentative plan is to go with a built-up system, due to SIP’s cost.
1. Looking for comments on Option 2 – Built-up roof system.
2. Looking for technical information on insulation options for the roofing system…
  • polyisocyanurate
  • polystyrene
  • blown in celulose
  • fibre batt
3. Primary concerns:
  • insulation longevity of polyisocyanurate
  • finding leaks in roof
  1. JonE | Jul 27, 2004 12:18am | #1
    What I'm using -
    SIPS, 6" EPS, premade with T&G on inside, OSB outside, 3/4" furring strips and second layer of OSB, 30# felt, I&W shield, asphalt shingles.   The air space created by the furring strips gives a "cold roof", good if you have snow and ice in your area.  Otherwise, omit it.
    1. JamesT | Jul 27, 2004 06:59pm | #2
      Thank you.
      That basically confirms my plan, and we need the airspace with minus 30 for two months in the winter...
      Jim
Outdoor Lighting
