roof jacks on shingled roof?
BartD | Posted in Construction Techniques on March 21, 2006 02:33am
can roof jacks be put on a roof that has already had the shingles applied?  can I just lift up the tabs and nail the jacks underneath the shingles?
  1. seeyou | Mar 21, 2006 02:45am | #1
    yes
    Birth, school, work, death.....................
    http://grantlogan.net/
    JDRHI | Mar 21, 2006 02:56am | #2
    Ya sure can....just be careful not to tear shingle when installing or removing jack.
    J. D. Reynolds
    Home Improvements
    dieselpig | Mar 21, 2006 03:16am | #3
    Like the fellas said... yup.  Make sure your nails go into framing and not just the sheathing.  Also try to find a spot to nail them that doesn't line up with a space in the shingles, this way you when you're done with your bracket, you just pull it and pound the nails into the shingles.  Tar the flap back down and you're done.  Pulling the nails just increases the risk of tearing the brittle shingles and doesn't serve much purpose.  Just make sure they're not protruding at all.... nice and flush.
    1. BartD | Mar 21, 2006 03:58am | #4
      thanks guys.  i appreciate the help.
    2. woodway | Mar 21, 2006 05:36am | #5
      Ok Ok, I'm missing something here. I assume you guys are talking about use on asphalt roof not cedar shake of shingle, right. And on a warm day too, so that the shingle wouldn't break. If it was shake then wouldn't you would have to pull the shake to attach the jack and then come back and reinstall a new shake?
      Just trying to know everything gives me a headache!
        JDRHI | Mar 21, 2006 05:39am | #6
        My wife knows everything.
        She gives me a headache.
        J. D. Reynolds
        Home Improvements
        dieselpig | Mar 21, 2006 06:54am | #7
        The original question referred to the "tabs" of the shingles.  So yeah.... not cedar.View Image
      3. seeyou | Mar 21, 2006 02:44pm | #8
        >>>>>>>>If it was shake then wouldn't you would have to pull the shake to attach the jack and then come back and reinstall a new shake?Yup.By the way, how much does a wood weigh?Birth, school, work, death.....................
  • Smarter Stop Block
  • Square Walls Solo
  • Deck-Board Pry Bar
