roof lantern
kostello | Posted in Photo Gallery on November 1, 2003 01:47am
just a little something i knocked up in the summer.
aleks
    SamT | Nov 01, 2003 05:58am | #1
    Smaller sized versions
    SamT
    "You will do me the justice to remember that I have always strenuously supported the right of every man to his opinion, however different that opinion may be to mine. He who denies to another this right, makes a slave of himself to his present opinion, because he precludes himself the right of changing it."   Thomas Paine
    Edited 10/31/2003 11:00:09 PM ET by SamT
    1. kostello | Nov 01, 2003 08:57am | #2
      how did you get them that small and still have them look ok?
      aleks
    2. kostello | Nov 01, 2003 09:35am | #3
      figured it out it's a JPEG not a bitmap.
      amazing how much smaller they are
      aleks
        SamT | Nov 01, 2003 03:59pm | #4
        ACDSEE, convert files to jpeg at %67 quality. Love ACDSEE.
        SamT
        1. kostello | Nov 01, 2003 06:24pm | #8
          Acdse??????
          whats that????
          aleks
            IMERC | Nov 01, 2003 06:28pm | #10
            AC / DC... Switch hitter, runs both sides of the fence...
          2. timkline | Nov 01, 2003 06:48pm | #12
            http://www.acdsystems.com/English/index.htm
            digital imaging software.
            carpenter in transition
            SamT | Nov 01, 2003 07:04pm | #13
            ACDSEE is a truly awsome image managing software.
            Dclik an image (any format) and view it, dclik the view and see thumbnails of all pics in folder, switch to View Details or List and batch convert any or all to any quality you want.
            Rclik a folder and see all images in there.
            Navigate folders, move or copy images, call up your favorite editor, set an image as wallpaper, run slideshows.
            I've got a shareware version, reminds you gently about every 100 views, hold the 'L' key down during long SS's, 1415KB in size.
            Email me and I'll send it to you. I'ld post it here as an attachment, but the management always deletes any exe's.
            If 2 or more of you guys want it I'll attach it and you can grab it while it's still up.
            SamT
  2. zztop | Nov 01, 2003 04:16pm | #5
    I was expecting to see a petite beach babe :-)
    1. kostello | Nov 01, 2003 06:25pm | #9
      how does roof lantern become a beach babe????
      aleks
  3. timkline | Nov 01, 2003 05:01pm | #6
    skip the beach babe, that is an awesome roof window !
     is this totally custom ?  it looks like the inside is aluminum tube frame, is this correct or is it painted wood ? how about the exterior, is that a custom copper flashing for the glazing ?
    really, really nice....
    1. kostello | Nov 01, 2003 06:23pm | #7
      yeah its wood, red meranti ,not my first choice but it machines pretty well.
      rafters have a roman ogee moulding on them.
      on the top the glass is retained on epdm gaskets and an aluminium capping held on with stainless steel screws.
      no copper. all the flashings are lead. fortunatley i did'nt get the job of doing those the roofer did them.
      its a listed building and the conservation officer said that they didn't want to be a ble to see the edge of the glass from the street hence why its set so low in the roof.
      its 2 metres square. ( 2'6"*2'6" in old money)
      aleks
      1. timkline | Nov 01, 2003 06:44pm | #11
        i was wondering about why the unit was set into the roof like that, which scares me a little bit from a flashing standpoint.  is this also why the glass slope is less than the roof slope, to make it less visible  ?   Where did you get the glazing caps and gasketing ?  was it a designed system ?
        1. kostello | Nov 01, 2003 07:07pm | #14
          the cappings are part of a system that we use on the conservatories i normally do. mad eby a company called exitex in ireland they don't have a website that i could find.
          this another system that we normally use because there is a cap that hides the screws http://www.twinfix.co.uk/twinfix_ref_300_1.htm
          the roof drains into small lead gutters on 2 sides and onto the roof on the other 2.
          i did my best to presuade them that the best system would be to have all 4 sides drain onto the roof but the conservation officer said that they wouldn't accept that.
          i don't know what's availiable in the US as i live in the UK where conservatories are everywhere nowadays they the current thing to have.
          aleks
  4. Tryit | Nov 01, 2003 09:28pm | #15
    Knocked up?
    1. kostello | Nov 01, 2003 11:30pm | #16
      not in the biblical sense.
      'To knock up'   :to throw together in a rush. that sort of thing.
      it was a job i got because i had the 2 days free to make and fit it before the roofers went in
      aleks
Podcast Episode 691: Replacing Vinyl Siding, Sloping Concrete, and Flat vs. Pitched Roofs
Listeners write in about ground-source heat pumps and weatherstripping and ask questions about engineered siding, concrete that slopes the wrong way, and why houses have pitched roofs.
  • A Postwar Comeback
