Roof patio/deck materials suggestions?
remodelman | Posted in General Discussion on September 17, 2009 11:46am
Anybody have any materials suggestions for a roof patio? It has newer rolled roofing installed over a pitched 2×10 frame that is in good shape. I’ve installed floating 2×2 ‘floor joists’ with 5/4 decking before, but was wondering about other options…specifically cheaper options…although that system does seem to be the simplest to me.
Any advice would be appreciated…so I can finish up another estimate that no one can afford.
  1. Piffin | Sep 18, 2009 02:50am | #1
    You are already a step late asking advice. Roll roofing is a 5-10 year roof is all. Mod bit or EPDM would have been best.
    Another option for you now is to deck the sleepers with marine plywood, and then do an elastomeric coating, or fibreglass it.
    For higher quality, go to a decking with Schulter's membrane/drainage plane system for exterior tiles.
    There is also a portland based coating system that I have read about here that seems fine for moderate climates. Forget the name of it. I think there is a vinyl roll out system for this sort of deck too.
Two Ways to Test Windows
  • The New Old Colonial
