Roof pitch on a lean-to
Sawblade | Posted in General Discussion on February 26, 2008 05:08am
I’m building a lean-to on the back of my shop.  Shop is an 8/12 pitch but has gutters, so no rainwater from the shop will feed onto the lean-to.  I would like to keep the “low” end up as much as possible for head clearance.  I will be using metal for the roofing on the lean-to.  What do you think is the most shallow pitch I should use.  In order to keep the “low” end up, it’s probably going to need to be 2/12.  Is this too shallow?
  1. Riversong | Feb 26, 2008 05:38pm | #1
    You could get away with a 2:12 roof, but make sure it's built to take the snow load.
    And I would suggest sheathing the roof with rough-sawn 1" boards, covering with 15# felt as secondary drainage plane, and using 1" gasketed screws (in the flats of the roofing) so that the points aren't sticking through.
    Riversong HouseWright
    Design *  * Build *  * Renovate *  * Consult
    Solar & Super-Insulated Healthy Homes
    1. Sawblade | Feb 26, 2008 05:47pm | #2
      Not much chance of snow here in S. Carolina.
      I know it's "just a lean-to", but I didn't want there to be an issue with drainage and the shallow pitch.
      1. Riversong | Feb 26, 2008 06:06pm | #3
        Well, you didn't say where you were located.
        But drainage protection is why I suggested solid (rather than skipped) roof sheathing and a secondary drainage plane.
        Design *  * Build *  * Renovate *  * ConsultSolar & Super-Insulated Healthy Homes
  2. seeyou | Feb 26, 2008 06:10pm | #4
    Depends on the roof material. Check the install manual for the specific product you're going to use. All metal roofing is not the same.
    http://grantlogan.net/
    Today we's learnin' about rawks. They's all kinds of rawks. These [picks up rock] is rawks which you throw. These here [throws rock at Rusty] is rawks that you get hit with.  E.Cuyler
  3. theslateman | Feb 26, 2008 10:29pm | #5
    If you used EPDM you can go down to 1/2 in 12 if you wish
Picture-Perfect Pergola
