Roof Rafter problem
jlscope | Posted in Construction Techniques on June 7, 2010 11:21am
Most homes have their roof rafters on top of the wall plate and hang beyond to form the soffit, but that is not what was done in a small section of my house. The rafters are notched so that they are actually inside the house. They are also undersized and I want to sister up some 2×6’s.There are 5 rafters like this on a short wall. Someone gave me an idea that might work. I need an opinion. Could I replace the wall plate with a header of 3 2×10’s at the top of the 2×6 wall and hang the rafters inside with Simpson LSSU210  U hangers?  The roof was recently shingled so removing the roof to restring the rafters is not a good option. This seems like the best plan for what I’ve got to work with. Has anyone had a similar problem? I’ve attached 2 basic pictures to give an idea of what the problem is.
  1. strils16 | Jun 07, 2010 05:09pm | #1
    In response.
    In order to help you with the situation we need to know what your end result will be? What is the problem? I have framed this way before, 10 or so years ago and I cannot recall why. Is the main problem the undersized rafter? As long as the floor joists, studs and rafters are all stacked to distribute load paths don't mess with it. If you are getting deflection from snow loads than sister a larger board to the existing rafter using the birdsmouth already established. Hope this helps.  Eric Rodabaugh, A&E Builders Corp. Long Island, NY.
  2. calvin | Jun 07, 2010 05:10pm | #2
    Do you have
    any ceiling joists on that wall to tie the walls together?
    If not, a ridge beam would be called for (or not, perhaps because of such  a short run or it's a shed roof attached to a full height wall).
    Here's another idea to further confuse you, but I think it might be less work, less interferance with the outside finish of the wall.
    Notch the studs and add a let in ledger below the top plates to rcv. the new sistered rafters..................
    or even less work, add blocking between the studs, below the plates to the depth of the bottom of the new sistered rafters.  The trip 2x's would still be in need of being padded out at 4-1/2" in thickness.
  3. jlscope | Jun 08, 2010 11:35am | #3
    There are 5 ceiling joists to hold the walls together. The notching of the studs to fit the header is what was suggested to me by someone else. Just wasn't sure if doing that transfered the roof weight correctly since the rafters would be on the inside and not lying on top of the wall. Thank you for the info! I'll be working on it soon.
    1. calvin | Jun 08, 2010 12:20pm | #4
      I assume you meant
      that you might notch in a LEDGER board instead of what you typed (header).
      These new rafters are being added and sistered (fastened) to the old, correct?
      I don't see why you cant rely on blocking instead of notching.  What's the span of those existing rafters?
      and the pitch of the roof (how long will that plumb cut be on a 2x6?
Versatile Vise
