I am a complete beginner/homeowner, not a professional, but I have done some roofing/basic carpentry and have fairly good tools and skills. My wife has a house with a very nice “shed” that is 55′ across by 27′ deep. It is a basic shed roof decked, papered and shingled. The roof is 10’8″ from slab to top at the front sloping GENTLY to 8′ at the rear. It currently has a al roof attached at the rear with flashing that has leaked. The decking is rotten for a couple of feet back from the edge. Fascia and soffit is all rotten. The framing seems to be OK. My thought was to tear the old aluminum roof off and tear out the rotten plywood and soffit, etc. I am strongly thinking about trying to use something other than shingles to re-roof it. Any thoughts about Ondura, Aluminum roofing, or ???? I want watertight and my wife says not to spend much money. Any suggestions?? Thanks.
Veneered wall paneling is popular for its clean style, but it's a surprisingly complex trim carpentry job to do well.
SawStop's Portable Tablesaw is Bigger and Better Than BeforeRelated Stories
CaliforniaRemodelingContractor.com
One thing to keep in mind is that, without special treatment, shingles should not be used on a slope any flatter than 3-4 inches in a foot.
Thanks. We recently married and I have moved in to find this really nice workshop area with a bad roof at the rear. I'd like to salvage the building. ANy thoughts as to what to use? I'm stuck with the slope of 1:12. I realize that the rise/run is suboptimal. Could I use aluminum? A product that Lowes sells called Ondura? Thanks
Here is a sketch of the problem. The shed is 8 feet at the rear and 10'8" at the front.
With that slope probably your best bet (zero leaks if properly applied) is a rubber membrane. Cheapest (but also least durable) would be roll roofing with liberal use of mastic. Metal roofing would be more durable and more attractive, but depending on the style (and your weather) you could have some problems with the laps sealing.
From what I've read on this forum from others, Ondura is not a good product--easily damaged, etc.. The slope is too shallow for shingles, so metal or roll roofing may be your best bet. Some people here have used EPDM on flat roofs, maybe that would work, but I'm not sue how expensive it is. I just saw an ad in The Journal of Light Construction for a product that is self-adhering like water and ice shield but intended for the whole roof. It's called "Peel & Seal;" they have a a toll-free number 800-882-ROOF, or you can go to http://www.mfmbp.com .
There are apparently other similar products--there was discussion about this just the other day her at Breaktime. Forgot the title of the thread, but it should still be here--something like "self-stick roofing." If you can't find it, you can click on the "advanced search" function at the top of the column that lists all the discussions, type in the words like "self stick roofing" and when it asks for a time frame choose something like "within the past week" and it should give you the discussion.
Edit: Discussion title is "peel-and-stick roofing: any good?" and is number 95416.
Edited 10/8/2007 7:22 am ET by Danno
Ondura is the biggest waste of money you could make so that is out
The pitch is too low for shingles so that is out
You want economy job so the EPDM is out
Which leaves you with metal and caulked laps, or roll roofing
Aluminum roofing is among the premium choices for metal roofing, just like its more expensive cousins, copper and zinc. That's partly because it offers superior corrosion resistance to regular ferrous (steel) roofing options. This characteristic makes it a frequent choice in coastal environments.
Hello @peterbivens2434 it looks like a good suggestion. Thank you so much for sharing.
