We had a heavy wind driven rain storm here in Massachusetts this past Saturday. I was in the attic and noticed that the sheathing along the upper part of the roof around the ridge vent was wet. The roof is asphalt shingles approximately 20 years old. I’m assuming it is a problem with the ridge vent based on the location and the fact that it was wet all along the ridge vent. Should this never happen if the ridge vent was properly installed and intact or is it a reasonable possibility if the wind speed and direction along with the rain align? I was planning on having the roof redone in the near future as it is starting to look tired. I’m just wondering if it is failing now.
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
It is a reasonable possibility with fairly strong wind-driven rain. Some ridge vents are better than others at preventing it, and installation technique is a factor as well.
Roof Ridge Vent Leak in Wind Driven Rain
Thank You. I called a local well reputed roofer this morning and his response was right in line with yours. He said if it happened again anytime soon he would come and take a look. I told him that the asphalt shingles are just about ready for replacement and he said to wait until March unless the leaking happens again before then. Also, as you did, he said the older ridge vents aren't as good as the newer products.
Jim
I've got some 25 yo ridge vent on the roof here. They don't and never have allowed water in. Old don't mean bad. I'll agree whole heartedly that there's both good and bad. New bad is bad.
Lower slope don't help and coastal conditions neither. We've had some good blows here, but live in a hill at the back (2 story one side-back only 1). The prevailing winds do not hit the house flat-they come in on an angle to the hip roof. Big blows (tornado's not miles away) didn't see moisture in the attic. The grounds slope and tree lines move the air currents up and over the house (which could help alot).
So, no leaks in yours for 20 yrs, you might have had a big event and bad luck.
Here's hoping it don't happen again.
About once every 3 years we get a blow that comes from the south and blows right up the slope of the roof. Water blows in the bathroom vent and a few drops come through the ridge vent. The cellulose in the attic pretty well disperses whatever comes through, though.
Exactly
There are several reasons for water intrusion-not all can be blamed on "old" product. The trick is to get the best product you can and eliminate all other things that will compromise your install.
Afterall, you are putting a pretty good hole in the roof, keeping the rain out does take a bit of thought.
Drips we can handle no problem-a gallon or two and you start to reach a point of little return.
Can't recall how many times I've replaced narrow flimsy metal ridge vent purchased at box stores with the stiffer wider stuff I get from my local yard.
carloa
Further proof why you should always Support Your Local Yard!
