Roof sheathing
| Posted in General Discussion on June 3, 2001 12:30pm
I am about to put a new roof on my house. It has about 3 layers which I will be stripping off. The sheathing under the shingles is about 8 inches wide. There are gaps between the sheathing of between 3/4″ to 1 1/2″. My question is should I put plywood over the sheathing or just fill in the gaps with strips of roofers? Or does anyone have any other ideas?
I’ve heard that if I put plywood up, I have to be careful about venting because plywood can restrict air flow. Any opinions?
Thanks, Clayt Westland
  1. david_thodal | Jun 02, 2001 08:41pm | #1
    Clayton, If the original sheathing is sound, and well nailed, I would reshingle over it. Adding plywood would be unnecessary. I would assume that the original shingles (composition?) had the necessary nailing, so I would assume that comparable sized shingles would be the same.
    You can lay out the nail lines first, to double check and fill in as necessary.
    Even without plywood, I would consider a ridge vent. Composition shingle can heat up considerably and having some airflow under the sheathing can help extend the roof's lifetime.
    walk good
    david
    1. Ron_Rosa | Jun 03, 2001 12:30am | #2
      *Fill in the gaos and add the vent. Good Luck
  2. Clayton_Westland | Jun 03, 2001 12:30am | #3
    I am about to put a new roof on my house. It has about 3 layers which I will be stripping off. The sheathing under the shingles is about 8 inches wide. There are gaps between the sheathing of between 3/4" to 1 1/2". My question is should I put plywood over the sheathing or just fill in the gaps with strips of roofers? Or does anyone have any other ideas?
    I've heard that if I put plywood up, I have to be careful about venting because plywood can restrict air flow. Any opinions?
