Roof style cost
CCI | Posted in General Discussion on March 21, 2007 06:57am
I was driving through a different area this morning and I noticed that alot of the houses were the same basic style except some had gable roofs and some had hip roofs.
What is the difference in cost – materials and labor – for one style over the other?  If you start with the same size footprint is a hip roof cheaper than a gable roof?
The hip roof has more complex framing but does it use less lumber?  It uses less siding but more shingles.
I was just wondering if cost is the major factor which is the cheapest? I personally don’t like the way hip roofs look but that is just my taste.
Thanks.
  1. user-201496 | Mar 21, 2007 07:11pm | #1
    A hip roof may only use about 5% more shingles, mainly for the ridge caps. The framing is again about 5% more in lumber. A good framer can do a hip roof in the same time as a gable roof. So with a hip roof you save the gable walls and siding. A hip roof should cost slightly less than a gable roof. Also a hip roof is also the strongest roof in a storm.
    CapnMac | Mar 21, 2007 07:16pm | #2
    Well, I'm thinking "style" has more effect than mere cost.
    Certain styles of building are defined by their roofs.  Hard to build a "Saltbox" with a hip roof.  A Prarie Style house with a 12/12 gabled roof would not be very likely, either.
    The "gray area" is in the "builder's ranch" house "style."  Since it's not really a formal style, per se, it can have all sorts of major details (although a gambrel roof might be a bit unlikely).
    To my mind, the major consideration for hipped roofs is the length of the hip rafters--which is one of my pet peeves with tract builders using canned plans with the current style of 9-12/12 pitched "circus tent' roofs.  I've seen one too many crews out there scabbing together whatever they have to make 30' hip rafters.
    "More expensive" is a question which is a bit of pandora's box, too.  Which is more critical, the immediate construction cost, or the lifecycle cost.  A 5/15 hipped roof foamed under the deck might be much cheaper over a lifecycle than a 10/12 gabled roof insulated only at the ceiling.
    Given that level of complexity, I'm thinking that's why, more often, we go with what "looks best."  But, that's opinion, and opinions differ.
FHB Podcast Segment: Patching Drywall Near a Shower
Learn how to patch drywall above a fiberglass shower without totally redoing everything.
