Roofer Installed Open End Ridge Vent Instead of Closed End Ridge Vent……What To Do
jimmiem | Posted in Construction Techniques on April 28, 2016 08:48am
New ridge vent was installed when I had my house re-shingled.  I noticed a lot of light coming into the attic from one end of the ridge vent.  The opposite end has no light coming into the attic.  The light end is a tough spot to reach from outside the house so I used an inspection camera from inside the attic and see that the end of the ridge vent is totally open.  It’s a Cobra vent by GAF.  I contacted GAF and asked if they manufactured a plug/cap to close the opening.  I was told that the vent kit provided closed end sections that are supposed to be installed at the ends of the vent run.   I assume that this means that the last section that is open  will have to be removed and replaced with a section that has a closed end.  Are there any other options to plug the end of the ridge vent that will be easier?   Roofer is long gone…..he left me with some additional problems which I have had to correct.
  1. calvin | Apr 28, 2016 09:13am | #1
    Jim
    spray foam would be a mess and deteriorate.
    How about a pc of thick backer rod?  You might be able to stuff in from the attic?
    A good masonry supply should have it by the foot.  Get a few diameters so you don't make more than one trip.  A good tight fit of what you can pack in should hold and seal.
    1. jimmiem | Apr 28, 2016 09:35am | #2
      Hi Calvin,
      How's it going?  I knew I could count on you for a good idea.  I did try to stuff some of the non-metallic material that grill cleaning pads are made from  but I didn't get a good seal and it is porous.  I'll get some of the backer rod.  I've got a painter coming to do some painting and when he has his staging set up I'll climb up and maybe do some of the plugging from the outside.  One other thing I considered is the clay-like material (can't remember what it's called) that utility guys use to seal pipe openings around wires.  I had a conduit installed (looks like a rain downspout) when my a/c lines were run to the attic and plugged the bottom with the clay stuff to keep bugs and rodents out.
      1. calvin | Apr 28, 2016 06:52pm | #4
        Jim
        Things are good.
        Real Spring can't get here soon enough.
  2. DanH | Apr 28, 2016 06:37pm | #3
    You want to be sure to insert some sort of metal mesh or the like to deter rodents.  You can, eg, scrunch up chicken wire and inject foam around/through it.
    1. jimmiem | Apr 28, 2016 06:57pm | #5
      I'd like to hire a roofer and have the open end section removed and replace with a closed end section.  But I'm not sure if it is a good idea to disturb what is there and risk a leak.
  • Townhouse Transformation
