Roofing 101
rez | Posted in Construction Techniques on August 28, 2006 07:16am
If adding a new roof addition (black) to the old (blue),
at the red arrow intersection after the new and old sheathing has been joined to a point, old low slope meeting new steeper slope,
what normal asphalt shingling technique is used there for continuing the water runoff over the slope point?
diagram  pretty much at actual angle.
 A bird does not sing because it has an answer. A bird sings because it has a song.
  1. jet | Aug 28, 2006 07:27pm | #1
    My two cents---
    Ice membrain and if possible same color singles but in low slope to extend the coverage over the splice.
    Maybe run metal flashing over the joint first???
    "No doubt exists that all women are crazy; it's only a question of degree." - W.C. Fields
    1. Piffin | Aug 28, 2006 07:37pm | #3
      Not bad for a jet engine mechanic!;)
      1. jet | Aug 28, 2006 07:41pm | #4
        gee thanks  LOL!"No doubt exists that all women are crazy; it's only a question of degree." - W.C. Fields
  2. Piffin | Aug 28, 2006 07:36pm | #2
    With an addition, there always exists the possibility of movement, either from settling, or from materials shrinkage. so either a metal strip spanning the joint and lapping over the lower tarpaper ( yes - use TP!) or a strip of Vycor or other I&W doing same.
    You are bsicly going to just shingle uip tp blend under the existing shingles, matching the pattern. You hope the old shingles are not too old and brittle to work the nails lose and slide new shingles under. Try to plan so patterns in shingle meet properly.
    1. rez | Aug 28, 2006 07:43pm | #5
Two Ways to Test Windows
  • The New Old Colonial
