Roofing pros: Detail when apron and step flashing meet open valley flashing
user-1163745251 | Posted in Construction Techniques on November 29, 2015 02:22am
Can someone please provide some guidance?
How do I detail the apron flashing that will come in from the right and the step flashing that will climb the roof to the left?
(The high shingle on the upper left was just tacked in an attempt to pick up coursing from bottom – ignore it)
Please help!
  1. user-1163745251 | Nov 29, 2015 03:30pm | #1
    Should I maybe close the valley at the top course and then run the apron over that to the center of the valley?
    1. junkhound | Nov 29, 2015 06:50pm | #2
      solder is ;your friend
    Mike_Mahan | Nov 29, 2015 07:47pm | #3
    Why....
    ...does it look like your valley metal is upside down?
    1. finefinish | Nov 29, 2015 07:51pm | #5
      MIke, That's just because the photo is sideways - it is a tropical illusion.  Just kidding...   looks correct to me.  It is in the "w" position, no?
  3. finefinish | Nov 29, 2015 07:49pm | #4
    Hi Jim, It is hard to tell from the photo a few key details that will help me make a recommendation.  Most importantly, where does the copper valley end and does it roll up the sidewall at all?  Is the last course of shingles that is top-nailed the exact kink where the roof and wall intersect?  Thanks
    1. user-1163745251 | Nov 29, 2015 08:41pm | #6
      Hard to tell...
      It rolls up a bit. W is not upside down. The last row is at the roof to wall intersection. Was planning to have the apron flashing lap the top row. Maybe 2 pieces of apron - 1 that sits under the shingles and laps the valley and then one that laps the shingles and follows the valley cut profile?
    2. user-1163745251 | Nov 29, 2015 08:52pm | #7
      And thank you!
      .... For taking some time out of your Sunday to think about this!
  4. DanH | Nov 29, 2015 09:36pm | #8
    In Firefox, if you right-mouse on the image and then select "view image" it will show the image right-side-up.
  5. user-1163745251 | Nov 30, 2015 10:17am | #9
    Thanks!
    I think I understand and it sounds like you suggest what my original plan was, adding the counter flash. One thing throwing me off is that there's a gap the thickness of the two layers of shingle between the valley flashing and the roof leg of the apron. At least 1/2" - certainly too big to solder...
    Any ideas?
  6. DanH | Nov 30, 2015 12:53pm | #10
    You can say that again!
