Rotted Window Sill
DTHA | Posted in General Discussion on March 29, 2009 03:07am
We will be replacing 22 windows in our house this week (Harvey slimline replacement windows).  All of the sills are in good shape expect two.  Fortunately, they are not too far gone as only the outside inch is damaged.  I want to cut off the bad and glue/screw a new piece on.  I made up some repair pieces similar to what Mike Smith made in the attached.  What is the best way to cut out the old inch or so of rotted wood?  BTW, these are fairly standard DH windows.
  1. Snort | Mar 29, 2009 04:11pm | #1
    We use a multimaster. And, if it fits your style, Lowe's has replacement pvc sill nosing.
    http://www.tvwsolar.com
    I went down to the lobby
    To make a small call out.
    A pretty dancing girl was there,
    And she began to shout,
    "Go on back to see the gypsy.
    He can move you from the rear,
    Drive you from your fear,
    Bring you through the mirror.
    He did it in Las Vegas,
    And he can do it here."
      Dam_inspector | Mar 29, 2009 05:09pm | #2
      I used to buy that nosing at HD, then they dropped it, special order only! Whassup wit dad? Now Lowes sells it, but they only recently started handling it. I see Lowes is getting rid of Kline tools, they will be exclusive to HD. I just wish they would take the best of both companies and hopefully have enough to make one good company. Lowes Depot.
    Ted W. | Mar 29, 2009 08:27pm | #3
    I use a reciprocating saw but it takes some practice to get a fairly straight line. If the cut is flush with the sheething and the sheething is expose, I would use 10" or 12" long blade and let it rest (bend) along the face of the sheething.
    A lot depends on the situation, how much of it you want to cut, how much stuff is in the way, etc. I've even used a hand saw to make the cut if necessary.
    MM works well but takes a long time.
    ~ Ted W ~
    Tool Auctions - MyToolbox.net
    See my work - TedsCarpentry.com
    1. DTHA | Mar 29, 2009 09:11pm | #4
      I was thinking of setting up my plunge router, anyone try this?
        Sphere | Mar 29, 2009 10:11pm | #5
        I'd maybe kerf it with a saw , hand, circ, or sawzall and break out the chunks with a chisel, then power plane it smooth. Can' see what yer working with as far as trim on the sides, so its a hard one to call.
        I personally don't equate router and demo in the same arsenal, but it could be done.Spheramid Enterprises Architectural Woodworks
        1. DTHA | Mar 29, 2009 11:42pm | #8
          It has brickmold on sides and top, sill on bottom, clapboards outside of that...  Just looking for a neat strait line.  Either a router with sled or power plane is looking like a good option as I do not have a MM (yet).
      2. MikeSmith | Mar 29, 2009 10:42pm | #6
        when  we  were  doing  a  whole  house  with  many  rotten  sills,  we  made  a sled  for  the  router  and  used  the  router  on them
        we  mad  many  small  passes,  probably  no  more  than  a 1/8 "  rout  each  timeMike Hussein Smith Rhode Island : Design / Build / Repair / Restore
  3. ted | Mar 29, 2009 11:20pm | #7
    I've done quite a few rotted sill repairs similar to what you describe. Never in any quantity but usually one or two at a time so I never bothered making a jig or fixture to facilitate things. Pretty straight forward procedure for me. I'd usually scrib a line just slightly beyond the rot then use a chisel to chop along the line being as straight as possible. Then follow with a block plane to straighten out the joint and glue and screw new material on
FHB Podcast Segment: Sometimes Spray Foam Makes Sense, Sometimes It Doesn't
Spray foam is a great invention, but it's not always necessary.
  • Tall Deck on a Sloped Lot
  • Making and Installing Wood Wall Paneling
  • Hand-Sanding Hack
