I’m planning on installing a 36″ x 80″ door in a wall. Can you please advise me the rough in dims as to how wide / tall should I plan for the opening.
Thank You
Thank You
This home features dramatic interior spaces enhanced by views of the surrounding trees and stream.
We can tell you, but there's a good chance we would be wrong. Go look at the door, or check the manufacturers spec sheet. It will tell you what the RO should be. Many people buy their doors and windows before framing begins so there's no mistakes.
Interior pre-hung door, 1" carpet clearance, rule-of-my-thumb = 38" x 83".
Nominal door width +2"; nominal door hieght +3".
Exterior prehung entry door with threshold - all bets are off - I don't have a thumb - seems like everybody is different.
Fasteddie has it right / safest - get the door first, or know what model you will be using, use manufacturer's recommendations.
Jim
Jim / Fast Eddy
Thanks for the response. I'll go with your advise, get the door and install per their specs. I do appreciate the input. I knew I could count on the list for the correct direction to take.
Stay Cool!
Frankl
My rule of thumb is generally 2" wider and taller than the door. Check the suppliers recommendations. I will reduce L and W by 1/2" if I am sure of the door measurements. You will need enough room to shim and plumb. Generally this involves movement room.
You install a door in an RO only 1 1/2" bigger than the door itself? How thick are your jambs?
I add 2 1/2" to the height and the width. That's a bit more width than necessary but just enough height, and it's an easy rule for my guys to remember.
