Rough in drain height
Griffin12 | Posted in General Discussion on August 5, 2009 09:24am
I am roughing in the plumbing for a 34″ high bath vanity with a standard drop in sink. What height should the drain be stubbed out?
  1. Shacko | Aug 05, 2009 11:49pm | #1
    If you don't want to figure it exactly put it in at 19in. off the floor. This is low, but it will allow you to hook up the vanity; put it in too high and you are fxxxed, luck.
    "If all else fails, read the directions"
    Edited 8/5/2009 4:50 pm ET by Shacko
    1. Griffin12 | Aug 06, 2009 01:02am | #2
       I was guessing about 18 inches so you have let me know I was on the right track. Thanks.
  2. brownbagg | Aug 06, 2009 04:07am | #3
    I was told by a plumber, the height of your hammer handle
      Matt | Aug 06, 2009 05:02am | #5
      That depends on how long your hammer is.
        popawheelie | Aug 06, 2009 05:44am | #6
        Hammer? Plumbers, get you mind out of the gutter!"There are three kinds of men: The one that learns by reading, the few who learn by observation and the rest of them have to pee on the electric fence for themselves."Will Rogers
    Jeff_Clarke | Aug 06, 2009 04:44am | #4
    The self-rimming lav manufacturer should have a rough-in guide that looks like this:
    In this case the dimension for the drain outlet is 14 5/8" down from the rim - your mileage may vary (check on-line via manfacturer).
  4. RajAkash | Jul 06, 2022 03:06am | #7
    To know about the bathroom sink plumbing rough in heights you must understand that sink drain lines should be between 18 to 20 inches. The water supply pipes must be some inches higher and it should be 20 to 22 inches from the bathroom or kitchen floor and it is generally installed to the drain line sides. This height is compatible with most bathroom sinks.
  5. Jacob_Andersons3 | Jun 11, 2024 11:44pm | #8
    For a 34"" high vanity, the drain is typically stubbed out at about 18"" to 20"" from the floor to the center of the pipe. This allows enough room for the P-trap and ensures proper drainage alignment.
    I recently needed affordable plumbing services and found a great deal through this comparison website. It made finding the best and most affordable plumbing services super easy.
    1. calvin | Jun 13, 2024 07:43am | #9
      A stink’n shame you forgot to include a p.o.s. Spam link.
    Nifelheim | Jul 01, 2024 06:17pm | #10
    Always look at the cut sheet of the sink and the vanity going into the space. You’ll get your answer there, no sense in guessing.
Picture-Perfect Pergola
