Router bit- tongue on floor sheathing
jonblakemore | Posted in Tools for Home Building on December 6, 2007 12:55pm
I’m tired of dealing with T&G plywood that has an actual coverage of 47-1/2″ (I think this is called “scant face”). I want to get a bit that will allow us to use ten rows plus a finisher of 16″ or so on a 40′ deep building. The alternative is 11 full rows and that’s a lot of extra money in Advantech.
Anybody have any recommendation on what type of bit to use? I don’t know if you can get a bit that will give a tongue that mates with the factory groove or if milling both T&G is necessary.
Jon Blakemore
RappahannockINC.com
Fredericksburg, VA
    IMERC | Dec 06, 2007 01:35am | #1
    do a spline....
    WOW!!! What a Ride!
      jonblakemore | Dec 06, 2007 07:28am | #4
      If we did a spline then we would have to rip a groove in the piece rather than a tongue, and fabricate the spline. Do you have any ready made solutions for spline material? I can't think of anything other than 1/4" Luam that would work for thats readily available.
        IMERC | Dec 06, 2007 07:31am | #6
        rips from a 1x hardwood...
  2. sawzall | Dec 06, 2007 04:50am | #2
    ten 1/2's is only five inches. How thick are your walls?  I would split the differance. Start your plywood 2 1/2 inches in, and you should finish 2 1/2 inches short. Then rip a pice of 1x4 to fill in. Your walls will straddle where the two meet.
      jonblakemore | Dec 06, 2007 07:29am | #5
      Our exterior walls are 3-1/2". We could use the 1x4, but that's kind of non-standard and may raise some eyebrows from customers.I realize that ripping a tongue on a piece of ply is non-standard as well, but maybe less so?
  3. reinvent | Dec 06, 2007 05:51am | #3
    If you really want to go that route then get this:
    http://www.amanatool.com/bits-fv/53600.html
    Comes with multiple spacers and slot cutters.
  4. brucet9 | Dec 06, 2007 08:24am | #7
    Check out this adjustable T&G bit from Freud. Should be able to match just about any tongue or groove.
    http://www.freudtools.com/p-155-adjustable-tongue-groove-bit-set.aspx
    BruceT
